odklizec
PK
R8 arrived! I'm now charging the battery so there is not much to tell about it right now, except to comment the exterior
It seems to be very well build. Visibly larger than R7. The body thickness is about the same as GRDII body. But it's not bad! It simply looks more professional Small grip helps enormously with holding the camera. The buttons are redesigned and I'm now able to click all of them without any problem (even with my rather large thumb). With R7, I was often not able to click the flash button just because it's too close to a protruded edge of the LCD frame.
OK, I also quickly started the camera with remaining battery, just to test the level of audible noise. I'm happy to report the R8 is now very silent camera. The level of audible noise is very low..maybe at the same level as GRDII. Definitely a big improvement over the R7.
BTW, the R8 LCD is gorgeous (with excellent viewing angles)! I will compare it with GRDII LCD, which is also superb. But from what I saw, the R8 can show much more details when the picture is zoomed in. The 460k resolution LCD is probably not a hype? It really works!
