Panasonic 20 mm F/1.7 ASPH LUMIX G - DoF
Tim,
(I assumed, from your units used) that Feet/Inches is your preference ... My program outputs that, so it made these calculations straightforward.
Here are two DoF tables for the
Panasonic 20 mm F/1.7 ASPH LUMIX G lens (with a 12.93 mm active sensor-height for the DMC-GF1).
This is "object-space" DoF using a circle Circle of Confusion based on the active sensor height and the vertical height of display pixels.
It is based on a 1x1 Pixel uncertainty, and assumes that the image is viewed close-up (as one can focus) by a 1080 pixel-height display.
It is somewhat conservative (relative to DOF Master DoF results) because it imposes a somewhat more rigorous standard for calculating DoF.
Note: Sensor to focal-plane distances (D) are in Feet. Output data is in Feet (or Inches).
F = 2.8 (Hyperfocal Distance = 38.82 Feet)
D=1---0.58"
D=2---2.40"
D=3---5.48"
D=4---9.85"
D=5---1.29'
D=6---1.88'
D=7---2.59'
D=8---3.42'
D=9---4.38'
D=10---5.49'
(If you have enough light to allow for a Shutter-Speed of 40 or greater at an acceptable ISO Sensitivity),
this interactive "applet" shows that the "lens-blur-index" for the lens-system appears to be near minimum at
F = 5.6:
http://www.slrgear.com/reviews/zproduct ... loader.htm
which is part of the entire lens review at SLR Gear:
http://www.slrgear.com/reviews/showprod ... 295/cat/67
The active sensor height is likely nearly identical on the DMC-GF1 as on the Olympus PEN EP-1)
Panasonic (as do all marketing behemoths) has such a nice way of framing the limited Depth of Field:
The new LUMIX G 20mm ƒ/1.7 ASPH. features a dramatic compactness and light weight
despite its ƒ/1.7 brightness allowing a beautiful soft focus for photos to be even more impressive."
So (given sufficient light/ISO for S => 40), you might prefer the rather improved performance of:
F = 5.6 (Hyperfocal Distance = 19.44 Feet)
D=1---1.16"
D=2---4.84"
D=3---11.16"
D=4---1.69'
D=5---2.72'
D=6---4.06'
D=7---5.75'
D=8---7.87'
D=9---10.54'
D=10---13.91'
Note that a sensor to focal-plane distance of 8 Feet yields a DoF of (approximately) 8 Feet ...
