Ricoh GXR Leica M mount!!!
kanzlr":3j9kow2y said:
I am sure it will be usable, but I am also sure that it will not be even close to a real range finder. Even DSLR screens with good matte screens are way worse than a range finder for manual focussing anyways.
To be honest, after using the Epson RD1 for a while I am not impressed at all by the RF focusing. It is impossible to focus in low light because you don't see the edges very well unless they are clearly defined and bright. Having used the NEX with focus peaking, it is a great way to focus and much faster than using a RF patch. So I would not dismiss this without trying.
bertalan wrote:
Sorry if these have been answered already but I see no ability for the camera to operate the aperture of the lens so I assume it is completely manual meaning that you focus with the lens wide open(to make it bright enough) then stop down to the dof you want to shoot.
You control Aperture via the lens, all M mount lens have a Aperture ring on them to control it. Metering should be auto as the camera will work it out.
Also you don't need to have lens wide open and then stop down for DOF, the LCD should show it on the fly.
But you will have to open the lens up to make it bright enough to focus THEN stop down to the dof you want
No need to do that, that's what what DSLRs do because of their auto-focus mechanisms (for normal focus, with live view this is not even always the case).
With manual focus and manual aperture you just set the aperture. The LCD will show it's normal exposure you manual focus and press the shutter release. There's no need to toggle the aperture.
Remko
Here are 5 pictures with one very interesting range finder looking one.
credit: http://dc.watch.impress.co.jp/docs/revi ... 65663.html
The last one is LEICA SUMMICRON 35mm f2 with integrated plate with viewfinder and holes for rangefinder windows. I'm afraid, these extra windows are useless on GXR. But yes, the plate definitely makes the GXR to look cool :D
Re: A Few Questions
odklizec":1p1598zu said:
bertalan":1p1598zu said:
Also, the dpreview site says that it has 720p30 movie, I assume this is mjpeg and will have completely manual control unless they do something silly like have auto ISO selection or some sort of auto gain. Does anyone have any more info about these items?
Yep, the Video mode should be pure manual, which is a good news if compared with existing A12 modules, with their fixed aperture and focus. Now you will be able to manually focus, zoom or even change the aperture while capturing the video. Of course, there may be captured clicking noise from changing the aperture ;)
Not if you are using those crazy Russian lenses with seamless smooth aperture control and no click stops.
To Help Tim out I also note that you can get good condition Industar 61L/Z lenses (with click stops) for US$16 plus freight. For a higher price that will still not break the bank a Jupiter-8 50mm f2.0 Sonnar design is a very nice little lens and works really well and has no click stops.
Very interesting. So Ricoh made the GXR body shape with sufficient clearance to take this rangefinder attachment. Was this an accident or was there some background thought process?
In any case given sufficient interest in the GXR-M there might be room to spin off this idea Into a new product in the form of a electronic/optical plug in viewfinder accessing the video feed from the GXR body.
Re: Not a "universal" M mount?
odklizec":wyrgylug said:
Tom Caldwell":wyrgylug said:
I am sititng there with a Jupiter 12 ready to use and just have acquired a Russar. I also have a GR28 #02613 ready to roar. I took a chance looking at the roomy interior of the prototypes.
GR28? Cool! I'm sure I saw a photo of the M mount with GR28 attached? So this one should definitely work. Current post at Ricoh GRblog shows M mount with attached GR21:
http://www.grblog.jp/2011/08/gxr-mount- ... ewdays.php
I have delayed getting LTM - M mount adapters as most on the market have been coded for Leica mount brightlines and I was unsure how Ricoh might deal with this. If I am right then there is no coding required and one simple LTM to M mount adapter will do the trick.
Oh yes, I hoped there will be implemented Leica coding system. But as long as there is an option to save the lens info into settings and save/recall these settings from memory/file, I don't really care about coding.
Still not sure about the Jupiter-12 as it has a 20mm rear protrusion. It has a great reputation and I would really hope that the M mount will handle it. Obviously one would understand that the GR28 should fit!
I believe there was, and probably still is a problem with mounting the M lenses on NX? I would not judge the possibility/impossibility to attach the M/L lens to M based camera because of negative NX experience. As far as I know, the NX is probably the worst system for usage with the M lenses? From what I found, Jupiter-12 works with M8/9 and so I guess it will work with A12 M mount as well? Read the discussion under this post:
http://www.stevehuffphoto.com/2011/01/0 ... -chisholm/
It seems it's older Jupiter-12 (made before 1971) what causes the problems?
Read the link, thanks. He is talking about the Jupiter-3 f1.5 and the Jupiter-8 f2.0 both 50mm Sonnar designs and very nice lenses to use. Of the two the J-8 feels slightly sweeter in use but the J-3 can produce knockout bokeh as he noted.
His prices seem a bit on the low side, so perhaps he was closer to the lottery, or prices are already on the move. For US$100 it you might still be able to buy a new (Russian speak) black J-8 and you might get a reasonably good black J-3 for $200. Black finish is generally better as it seems more durable. But black finish J-3's are rare and bordering on collector's pieces and might shortly start to take on closer to Leica prices.
These lenses because they are Sonnar design have little back protrusion. Not only this but I have been using both for a while on my NX. Great little lenses. Peculiarly the aperture ring rotates as the focus is changed (in synchronisation) ok once you get used to the notion. But you might have to lend a finger to hold focus when changing aperture - remember infinite aperture settings (no clicks).
The Jupiter-12 is something else - a Biogon design and so beautiful everyone should have one on their desk as a paperweight. It's rear protrusion is about 20mm. Looking inside my NX there is plenty of depth to fit one but the interior shape of the mount is "all wrong" - light baffles and a ledge to hold the electrical contacts quickly put paid to any notions of fit.
Reading postings on the credentials of the Jupiter-12 it seems to be regarded as "the best" of Russian rangefinder type lenses. It is 35mm f2.8 and as far as I know was made for a very long period without changes so that the first lenses assembled from actual Zeiss factory WWII parts are much the same as the last ones made probably 50 years later.
Again the silver ones seem to show wear and tear more easily. However well worn exteriors do not mean that the optics are no good. However after 30-50 years the original grease has perhaps turned to treacle from too many Russian winters. The contrast between a nice Leica lens and a nice Russian one is that for the price of a Leica one might expect it to be reliably overhauled by a competent tradesman. The Russian lenses are more like still in ex-factory condition less bumps and scratches and so-many cold winters, or worse, fixed up by Boris on the kitchen table with his mechanic's toolkit. However at the price I am happy with the value despite a few mistakes on the way.
Not that dealing with those in Russia or the Ukriaine is fraught. I have met my share of fleamarket stall owners but even these are honest with in their adopted trade. There are also some very reputable folk to deal with and their products are invariably as described and not over-enthusiastically so and good to deal with. Honest brokers do exist the world over folks are folks. Nevertheless as with any second hand purchase some prudent caution is necessary.
Shimming for focus is less of a problem on digital as there is no cam to worry about and the focus confirms visually anyway. More like the problem is that when Boris re-lubricated the helix he misaligned it putting it back together and the focus just ain't right at all. Screws get broken and the focus index ring might not be properly aligned.
So tales of woe about "Russian lenses" in my opinion are more to do with amateur repairs than the original quality control.
Yes and somehow someone managed to test the Zeiss Biogon "twin" of the Jupiter-12 in a NEX body. Seems that they are very sharp in the centre and not so sharp at the edges - methinks the Ricoh microlenses might be useful provided the Biogons fit in the mount.
Thought I might start chasing up adapters to fit other lens types on to a Leica M mount. LTM adapters, no trouble, I have even found a M42 to Leica M.
But others? everything seems to be going the other way - adapters to fit Leica M lenses on something else. These were supposed to be easy-peasy. I must be missing something?
I would be happy to find a FD->Leica M and a PK->Leica M.
I presume lens coding on LTM->Leica M has no bearing and this can be ignored.
Tom, I'm on the same boat like you. I already found two adapter makers, who make and sell various M-based adapter. However, their prices are rather ridiculous.
You can try for example Novoflex (149Eur per adapter):
http://www.novoflex.com/en/products/ada ... er-finder/
Rayqual is another one. These adapters are used by Ricoh Japan (170Eur per adapter):
http://www.japanexposures.com/shop/prod ... cts_id=383
And here is one cheep ebay seller with LM adapters for certain brands (not all):
http://stores.ebay.com/ROXSEN/For-Leica ... m322&gbr=1
Just by a luck, I recently bought on ebay a Leica M39 to Pentax K adapter made by Novoflex (for 40EUR). So now I need also Leica M to M39 adapter, but these can be found dirty cheap on ebay. True, the quality may vary.
I'm still looking for more adapter makers ;)
And here is another adaptor for Nikon - M which opens the door to a huge number of superb Nikon lenses. Just a pity Nikon dropped the aperture ring on their DX lenses as the 10.5mm fisheye is fabulous.
Have to organise a Ricohforum hunt and search, surely ther emust be more adapters about? Obviously people are more interested in putting Leica M lenses on other cameras than fitting other lenses on a Leica M mount.
Will check your links but the adapters seem a fabulous price. Are we all going to be using our M mount and LTM lenses happily whilst giving soothing caresses the other potential lenses that can be used with our other hand?
Also does Novoflex make a line of adapters in anything other than Novoflex blue? For some situations their trademark blue is fine but for a lens adapter it is a bit over the top. I believe they once had lines made in black finish.
Compared to the sleek black professional looking Samsung variety the Novoflex pk->nx adapter is blue, more "agricultural in finish" but nevertheless well made. The price is similar - give me the Samsung oem one any day. Might lend the official maker of Ricoh adapters a closer look.
I can't see why this combination shouldn' work very well. My only concern is that adapters are of variable quality. It would be nice to have a try before you buy option. I have had LTM - M adaptors that didn't fit correctly and they following link about an M - NEX problem highlights this. Novoflex is a quality manufacturer so their adapters should be OK.
http://www.stevehuffphoto.com/2010/12/2 ... l-barclay/
At the moment you can count the number of different type adapters on the fingers of one hand and you will need an army of hands to count how much they cost. Canon produced an FD-LTM adapter (type B) which then can be further adapted up to M mount. If other types of adapters are available to LTM then the second adapter might be a feasible way to go. But it would be nicer to direct adapt to M mount in the first place.
I have had no problems with Chinese made adapters (nor Russian made for that matter) for other lens types. Not that Novoflex and other well know makers do not doman excellent job but it is one heck of a lot to pay for some re-assurance.
In any case there is not much choice right at the moment but that might change.
I had the chance to use one over the weekend for a few hours and have posted my impressions here:
http://ricoh-gr-diary.blogspot.com/2011 ... sions.html
Here some of the main points.
- The bulge on the side for the shutter is actually great in use since it fits your hand very well and makes focusing the lenses very comfortable.
- You have the choice between two modes and different mangnification ratios.
The first mode is similar to the peaking mode you can find in the Sony NEX cameras with the difference that the conrast areas don't appear in red but shimmer white/grey, this works very well but I would like to maybe see an option to choose the colour in a firmware update.
The 2nd mode and my favourite is a kind of high pass filter mode, you have to see this in action to fully appreciate how great it works. After using it, I can honestly say this is simply the best and fastest way to manually focus.
- The physical shutter is very quiet, especially when compared with the GF1 or RD1 but even the Sony NEX-3, I would go as far as to say it's the quetest shutter on any mirrorless camera but have not had enough experience with Leica M cameras. The ability to close it when the camera is powered off is great and something other manufacturers should do.
The electronic shutter is only available as a scene mode and requires full manual control when it's enabled. Ricoh says it shoudl not be used for moving subjects but I took pictures of people and when moving myself without any problems.
- The sensor, Ricoh has said they have modified it to work with a wide range of lenses and especially wideangle lenses, which are always a bit problematic. As you can see from the pictures above the sensor is certainly improved and from the looks there is also no AA filter in place. Ricoh has confirmed that the glass filter they mention in the presws release is more an IR filter and to help eliminate any lens aberrations. The image quality is certainly much better than what you get from a GF1 with m-adapter but also better than what the RD1 achieves and without the heavy vignetting (especially when using the Heliar lens).
Thanks Cris for great preview! Those images look nice and it's great to hear how usable are the focus assist modes. The Nokton looks absolutely stunning on GXR. I can't wait to try it myself! Just bought an interesting lens (85/1.4) to try it with the M module and I have another one in sight (pancake 28/2.8). We will see how they will turn out.
Just one question. Did you try the corner correction features? Are they usable also in RAW or just in JPEG?
Pavel, I am sure you'll like the module and the 2 lenses sound like a good starting point.
I did try the corner correction feature but did not keep the picture to check if it was for both RAW or JPG. I have to say that there was actually no need to correct any of the lenses as even the 15mm performed very well and had no vignetting at all (or that I would have noticed).
Hi Pavel
Just out of curiosity, which 28mm/2.8 are you going for? So you gave up getting the Nokton 40mm/1.4?
Cheers
Fabrizio
PS: also after reading Cristian review - I may go for the Nokton 35mm/f1.4.... thinking....
