Blow-in":3hnep9ej said:
Tom,
I took the Accmaxx cover off my GRD4 six months ago as it was trapping specks of dust behind it and annoying me - so far so good. A top tip is turn-up the brightness of the GRD4 screen to max to really see what is going on and carry a spare battery.
I found I had a spare Accmaxx cover in a drawer that I had bought to fit on my GRDIII, therefore excess-caution won in the end. It is interesting that dust can get under it. The only comments I have on my Accmaxx screens is that they are generally problem free, they are hard-surfaced and seem scuff-free and the way they are cut gives what appears like a professional-type restrained visual "frame" on th eedge of the cover. The only problem I have had was one of my camera screens became hot and a bit of sideways pressure in a case caused it to slip alignment due to partial glue release. I worked it back into proper position whilst still "hot" and have had no further trouble.
Also the Accmaxx screen obviously protrudes just a little, but that cannot be helped even though it might be nicer flush-fitted to the back of the camera. The GR comes with some sort of hard cover in place. The NEX6 had a flush hard clear surface over the whole back surface area of their tilt screen as much as Samsung and Canon have always done something similar. About time Ricoh - but in their defence Sony must have originally thought that their anti-reflective lcd coatings were robust-enough, until the "dawning" ....
Getting dust under the screen? I wonder how? Perhaps the glue is not 100% in contact around the edge? Even on my "brand-newy" GRDIV almost as soon as the packing clear cover was removed the dust was already settling (darned stuff is everywhere!) and so I blew it off pretty seriously with a little air-compressor blower as I was not wishing to whisk it with even the cleanest cloth. So maybe some micro specks still make it under there even in the best managed situations. So I imagine that this might be the problem rather than some sort of insidious dust-leaking aperture in the construction.
By comparison I have the JJC Hood with side screens on the GRDIII. It has an inner glass cover and the hood can be clipped off and reversed or simply not used. It seems the ideal solution to bright light washing-out the lcd. Unfortunately the GRDIII had a good life with an unprotected lcd until the lcd surface crazed. Mine was #00006 in the Australian delivery batch so I was certainly an early cab off the rank with that one. But by the time the distributor kindly replaced the lcd for me I was up to my hocks in GXR-M-love and I have hardly used the light-baffle equipped version to judge its effectiveness.
Nothing like the present - bright sunshine today in autumny Australia - probably only 20C maximum, what can you expect with winter coming on?
Yes the side baffles do help "a bit" - they are certainly not a complete answer and it is a toss up if the extra bulk of the contraption on the back of the camera is worth the benefit given. Certainly when "bulkier" makes it used less often and you have not previously noticed whether the three-sided light screen has been effective or otherwise. Maybe if I turned up the lcd brightness more - as you reasonably suggested?
Certainly the nice svelte little GRDIV seems more appealing to grab and take on a saunter than the more porky looking GRDIII with it's contraption piggy-backed.
