News New Ricoh GR IV monochrom
JAGR
Just saw this, so is it official now?
Wow that is amazing!
Just saw it on the rumor site:
  • Expected to be release in late 2025 or ealry 2026 (spring 2026 - see press release below)
  • 25.7 MP sensor
  • 18mm f/2.8 (28mm equivalent)
  • Monochrome sensor
  • ISO: 160 to 409600
Press release:
RICOH GR IV Monochrome High-end Compact Digital Camera Development News​
Equipped with a dedicated monochrome image sensor for the ultimate in black and white expression
TOKYO, October 20, 2025 — RICOH IMAGING COMPANY, LTD. is pleased to announce the development of the RICOH GR IV Monochrome. It is the first model in the high-end GR compact digital camera series designed specifically for black and white photography.
The RICOH GR IV Monochrome, which is currently in development, is based on the latest model, the RICOH GR IV, which was released in September 2025. It is equipped with a new, dedicated monochrome image sensor and Image Control options specialized for black and white photography to deliver the expressiveness and depth unique to monochromatic images.
It has been nearly 30 years since the RICOH GR1 film camera, the first in the GR series, was released in 1996, and exactly 20 years on October 21 since the GR DIGITAL was launched in 2005.
Over the history of this series, our commitment to the essential camera values of high image quality, quick response and portability has always remained the same. Hinging on these basic concepts, the GR series has continued to evolve to meet the needs of the times. We hope you are excited about the RICOH GR IV Monochrome and this new foray into black and white territory.
Overview of the product under development
  • Model name: RICOH GR IV Monochrome
  • Launch date: Spring 2026 (planned)
  • Price: TBD
Note: The exterior design sample of the RICOH GR IV Monochrome, which is in development, will be showcased at GR SPACE TOKYO starting on Thursday, October 23.
| Major Specifications |
LensLens Construction7 elements in 5 groups (3 aspherical lens elements)
 Focal Length, Aperture18.3mm (Approx. 28mm in 35mm equivalent focal length), F2.8~F16
Image Capture UnitImage SensorMonochrome, CMOS. Size: 23.3 x 15.5 (mm)
 Effective PixelsApprox. 25.74 megapixels
 Sensitivity (Standard output)ISO160 to ISO 409600: Auto (ISO Auto Lower/Upper Limit and Minimum Shutter Speed can be set), Manual
 Image StabilizationSensor-shift shake reduction SR” (5-axis)
 AA Filter SimulatorMoiré reduction using SR unit (Off, Low, High)
 Dust RemovalImage sensor cleaning using ultrasonic vibrations “DR II”
File FormatsStill ImageFile Format: RAW (DNG) 14bit, JPEG (Exif 2.3), DCF2.0 compliant
Color Space: sRGB、AdobeRGB
Recorded Pixels:【3:2】26M:6192×4128), M(16M:4944×3296), S(8.2M:3504×2336),
XS(2.5M:1920×1280),
【4:3】(23M:5504×4128), M(15M:4400×3296), S(7.3M:3120×2336),
XS(2.8M:1920×1440),
【1:1】L(17M:4128×4128), M(11M:3296×3296), S(5.5M:2336×2336),
XS(1.6M:1280×1280),
【16:9】L(22M:6192×3480), M(14M:4944×2784), S(6.9M:3504×1968),
XS(2.1M:1920×1080)
 MovieFile Format: MPEG4 AVC/H.264 (MOV)
Recorded Pixels: Full HD (1920×1080, 60p/30p/24p), Sound: Built-in stereo microphone
Recording Time: Up to 25 minutes or 4GB; automatically stops recording if the internal temperature of the camera becomes high.
 Storage MediumInternal Memory (Approx. 53GB), microSD/microSDHC/microSDXC Memory Card (Conforms to UHS-I standards)
FocusTypeHybrid AF (Image plane phase-matching and Contrast detection)
Focus ModeAuto-area AF, Zone Select AF, Select AF, Pinpoint AF, Tracking AF, Continuous AF, MF, Snap(0.3m,1m, 1.5m, 2m, 2.5m, 3.5m, 5m,∞), ∞
Focus LimiterNear Side, Far Side, OFF
Full Press SnapPerforms shooting by focusing at the Snap distance with a single press of the Shutter Release Button or a touch of the LCD Monitor
 Face/Eye DetectionON, Use only in Auto-area, OFF
 Focus Range (From lens face)Normal: Approx. 0.1m~∞, Macro Mode: Approx. 0.06m~0.15m
ExposureExposure ModeProgram AE, Aperture Priority AE, Shutter Priority AE, Snap Distance Priority AE, Manual Exposure
 Metering ModeMulti-segment, Center-weighted, Spot, Highlight-weighted
 Shutter Speed1/4000 sec. – 30 sec. (Limit by aperture setting F2.8: 1/2500 sec, F5.6 or greater: 1/4000 sec.)
Timed Exposure (10sec. – 20min.), Bulb, Time
 EV CompensationStill Image: ±5EV, 1/3EV steps, Movie: ±2EV, 1/3EV steps
Drive ModeDriveSingle Frame Shooting, Continuous Shooting, Bracketing, Multi-exposure, Interval Shooting, Interval Composite
 Self-timer10 sec., 2 sec., OFF
Shooting FunctionsCropOFF,35mm,50mm
 Image ControlStandard, Solid, Soft, Hi-Contrast, Grainy, HDR Tone, Custom1, Custom2, Custom3
Adjust parameters: High/Low Key Adjustment, Contrast, Contrast (Highlight), Contrast (Shadow), Sharpness, Shading, Clarity, Toning, Grain Effect, HDR Tone Level (Adjust parameter varies depending on the selected image setting)
 Dynamic Range CorrectionHighlight Correction, Shadow Correction
 Noise ReductionSlow Shutter Speed Noise Reduction, High-ISO Noise Reduction
 Horizon CorrectionSR On: correction up to 1 degrees, SR Off: correction up to 1.5 degrees
 DisplayDisplay magnification (4x, 16x), Grid display (4×4 Grid, 3×3 Grid), Histogram, Bright area warning, Electronic Level
Playback FunctionsPlayback ViewSingle frame, Multi-image (20, 48 frames), Display magnification (up to 16x, 100% view and Quick Zoom view available), Histogram (Y histogram), Grid display (3×3 Grid, 4×4 Grid), Bright area warning, Auto Image Rotation, Folder display, Calendar Filmstrip Display
 Base Parameter AdjustmentParameter: Brightness, Toning, Contrast, Sharpness
 RAW DevelopmentRAW file select: Select Single Image, Select Multiple Images, Select a folder, Select a shooting date
RAW Development Parameter: Aspect Ratio, JPEG Recorded Pixels, Color Space, Image Control, Peripheral Illumination Correction, Sensitivity, High-ISO Noise Reduction, Shadow Correction
 EditDelete, Protect, Image Rotation, Image Copy, File Transfer, Resize, Cropping (Aspect ratio and Slant adjustment available), Levels Adjustment, Movie Edit (Cut), Movie Edit (Divide), Save Movie Frame as Image
LCD MonitorType3.0 inch TFT color LCD (aspect ratio 3:2)、Approx. 1037K dots, Wide viewing angle, Air-gapless tempered glass
Touch ScreenCapacitive sensing method
 AdjustmentsBrightness, Saturation, Blue/Amber, Green/Magenta, Outdoor View Setting: Auto, Manual(±2 Steps)
Wireless LANStandards2.4GHz : IEEE802.11 b/g/n/ax
5.2GHz : IEEE802.11 a/n/ac/ax (Not supported in some regions)
5.8GHz : IEEE802.11 a/n/ac/ax (Not supported in some regions)
 Operating frequency band range2.4GHz : 2400MHz to 2483.5MHz
5.2GHz : 5150MHz to 5250MHz (Not supported in some regions)
5.8GHz : 5725MHz to 5850MHz (Not supported in some regions)
 Communication bandwidth2.4GHz : 20MHz
5.2GHz : 20/40/80MHz
5.8GHz : 20/40/80MHz
 SecurityAuthentication: WPA2™, WPA3™ / Encryption: AES
InterfacesUSB Type-CBattery Recharge/Power Supply (Optional AC Adapter required), Data Transfer: MTP, Video output: DisplayPort over USB-C (DisplayPort Alternative Mode)
 HotshoeCompatible with dedicated flash
Flash Mode: Flash On, Flash On+Red-eye, Slow-speed Sync, Slow Sync+Red-eye
Flash Output: AUTO, 1/1, 1/4
 Lens adapter pinAvailable
Power SupplyBattery TypeDedicated rechargeable battery
 AC AdapterAC adapter compatible with USB Power Delivery, AC adapter (D-AC166; optional)
* The camera is compatible with USB Power Delivery, but is not certified with the USB Implementers Forum logo.
 Battery LifeTo be finalized
Dimensions and WeightDimensionsApprox.. 109.4(W)×61.1(H)×32.7(D)mm (excluding protrusions)
Lens part:31.3(D)mm
Body part:24.5(D)mm
 WeightTo be finalized
Included AccessoriesDedicated rechargeable battery, USB Cable, Handstrap
Note: The designs and specifications are identical to those first announced publicly about the camera’s development, and are subject to change without notice.
This is tough for me. I just got the "normal" GR IV yesterday. Of course I am interested in the monochrome....
Well i waited out on the IV and also wanted it to first have most it's babycramps from first production sorted out.
As I do some film still, but has lost access to any darkroom etc, i am thinking heavily on this one as i could do what i like (b&w foto) without the costs of the analog world. If they don't skyrocket the price of the IVmono, i am most likely getting one.
I would be interested if the price was not prohibitive (not much higher than the current IV).
K-3 Mark III at launch: $1,999/€1,999
K-3 Mark III Monochrome at launch: $2,199 (+10%) / €2,499 (+25%)
Since I was asked whether or not I would buy a GR IV monochrome. Clear answer. I would have gone for it if I havn‘t got a III X for a Couple of month. I have it because earlier Communication about a IV was so bad and unprofessionally and I couldn‘t wait any longer. I needed a Little cam for my motorcycle Trip. Now it is too Late for both IV and IV mono to get. Cheers Anselino.
Do not regret it. The GR3x is a great camera.
It is normal that Ricoh did not say anything in advance. They want to clear all stock first, before introducing a successor. Most brands do it this way.
IMHO this is why they will now introduce first the monochrom before they will offer a GR4x. Because they still have too many GR3x available ;)
I have always been happy with my GXR in b&w and I have just added a Lumix S9 to use in the 24x65 format and Leica Monochrom setting so time with tell, plus whatever the $$$$ will be.
Released.
Official shop price 1799€
The price is steep. That does not mean that it is not worth it. All brands increase prices and a monochrome sensor will not ne produced in high quantities, because it is so special.
Compared to a Leica Monochrome, it is a a bargain.
