M mount lenses compatibility list
Re: official M mount lenses compatibility list
Please add the following lenses which I have used on the A12 mount:
Zeiss 18mm F/4 Distagon M Mount
Voigtländer 75mm F/2.5 Colour Heliar LTM
-- David
Hi Pavel,
I thought you had it already, but this one seems still to be missing from your list: Zeiss C Sonnar T* 1,5/50 ZM
(tested with hundreds of photos and also recommended to me in this forum).
I also successfully use the Voigtländer Super Wide Heliar 1:4.5/15 mm and the Elmar C 1:4/90, which are already on your list.
In addition, I just ordered the Voigtländer Pancake: Voigtländer 1:2.5/35mm Color Skopar Pancake II.
Hopefully, it will also be compatible... BTW, your Voigtländer list looks a little incomplete...
Best regards,
Gerd
odklizec":3sexfz0n said:
spylaw4":3sexfz0n said:
A rarity, but you can also add the Kobalux/Avenon/etc. 21mm f2.8 to the compatible listing. Works fine.
Brian.
Hi Brian,
Is this Kobalux equipped with L or M mount?
It has an L39 mount - but I use it with the M bayonet adapter.
Incidentally the new Leica 21/3.4 is (naturally) compatible - I tried one on the GXR today.
odklizec,
Just to be not confused, I'd alter the name for this thread to "M mount lenses compatibility list" since now it became non-official ;)
Now it's clear: the Voigtländer 1:2.5/35mm Color Skopar Pancake II is compatible, too.
Best regards, Gerd
Sorry, I am just in a "Kaufrausch" (buying frenzy)* and bought the Voigtländer Skopar 4,0/ 21 mm. Hopefully, I will be able to report that it is compatible in a couple of days (as far as I see, people posted already photos with this lens).
Best regards, Gerd
*) I hope, I am done for while...
Best regards, Gerd
I confirm that CV Color-Skopar 21/4 M mount lens is compatible , as well as M-Hexanon 28/2.8 KM mount lens
Waloszek, braeside and olch, thank you for your reports guys! I will update the list accordingly.
Slappo, just follow the initial post (here) ;)
i can report that the
cosina voigtlander ultron 28mm f1.9 screw mount
and 50mm f1.5 nokton screw mount , both with screw mount to M adapters
work perfectly and have excellent performance at the corners both in minimal light falloff and sharpness ,[ i also think the perf of the 15mm 4.5 is stellar , its already on the compatible list
Carl Zeiss Biogon 35mm f/2 works fine.
Carl Zeiss Planar 50mm f/2 works fine.
(I expect that all M and LTM lenses will be fine, except for a very few special ones...)
LEICA SUMMICRON-C 40mm f/2 works well.
Well, I think it is the same as the Minolta M-Rokkor 40mm F2.0 :)
And now I've also to report a fast lens that works fine:
Voigtlander Nokton SC 1,4/35mm - mount VM
Bye
AndyG
Hallo guys,
I am new on this Ricoh Forum.
My name is Thomas, I live in Berlin Germany.
Last week I bought a new GXR and the M-Mount.
I ordered a Zeiss 18mm, 4.0 and I use a Summarit-M 50mm F2.5.
It works fine :D and you can add it to your compatibility list.
Best wishes
Thomas
