The AC Adapter & Tripods
sciascia
Hi There,
Just ordered a GR II yesterday and have what is hopefully a dumb question: How do you power the camera using the AC adapter when the camera is mounted on a tripod? It looks like you can't have the battery door open when the camera is mounted - is there room for the cord once the door is closed?
Also, it looks like you can't change memory cards when the camera is mounted on a tripod - is that correct?
Cheers
Hi sciascia and welcome on board!
You can't have the battery door open while the camera is on a tripod. However, there is a small plastic tab (next to the battery door), which can be pulled out and where can be lead the charger cable. The same tab is on GRD and GX100.
