thelps
- Joined
- Nov 5, 2007
- Messages
- 3,614
For some years many people have asked Ricoh to make a 35mm equivalent GR Digital. Others have wanted a 50mm and even longer versions with some suggesting a pure 21mm equivalent compact. I found little on the net to explain the GR 35mm technical dimensions so am posting some boring numerical findings here for reference.
I felt it most appropriate to study the 35mm mode using the camera in 3:2 mode. This is closer to 35mm film in ratio than 4:3 mode. Most users I suspect would come from this ratio. Perhaps those using 6 x 4.5 medium format or 8x10 film would find the 4:3 closer. Fair enough too.
Some numbers for 28mm & 35mm crop mode --
4:3 Ratio
28mm 4:3 ratio the RAW image is 4368 x 3280 pixels
35mm 4:3 ratio the RAW image is 3504 x 2624 pixels
3:2 Ratio
28mm 3:2 ratio the RAW image is 4944 x 3280 pixels
35mm 3:2 ratio the RAW image is 3952 x 2624 pixels
1:1 Ratio (square)
28mm 1:1 ratio the RAW image is 3280 x 3280 pixels
35mm 1:1 ratio the RAW image is 2624 x 2624 pixels
Note: Looking at the EXIF info the in camera generated jpeg files are all about 16 pixels smaller than the RAW sizes quoted above. It would be interesting to know why?
For additional reference the 28mm GRD IV sizes are as follows --
4:3 ratio the RAW image is 3648 x 2736
3:2 ratio the RAW image is 3648 x 2432
1:1 ratio the RAW image is 2736 x 2736
What we can see here is the resolution for 35mm mode on the GR is only slightly less than the GRD IV 28mm camera.
Angles of view for 35mm film - generally the diagonal is quoted
28mm is 75 degrees
35mm is 63 degrees
A 35mm 3:2 mode image. Jpeg from camera. No PP, re-sized only
A 35mm 4:3 mode image. Jpeg from camera. No PP, re-sized only
A 35mm 1:1 mode image. Jpeg from camera. No PP, re-sized only
Ricoh’s description of 35mm Crop mode is here - http://www.ricoh-imaging.co.jp/english/products/gr/feature/03.html
The question arises should you just crop a 28mm image to 35mm in post process? Well IMO some people like to "see" in 35mm while making the image so while cropping is an option I think the addition of the mode in camera is very valid. If 35mm is your thing you have the option to put it on 35mm and leave it there or set it as a MY option.
The GR shows the actual full "35mm image" while in 35mm mode on its LCD so it does become a 35mm camera. Using a 35mm OVF on the hot shoe is another possibility.
The Ricoh GR a 28mm camera at its core, that is the mode mine will be used in. Can the GR act as a 35mm camera? IMHO I believe yes and with a level of IQ that still exceeds some competitors. On another note there are only a few other compact cameras that can start up in 35mm equivalent angle of view like the GR can. The IQ loss in sensor size is not that great as the GR sensor is quite large to start with.
Is it for you? Try it and let us know. For me the GR remains a 28mm camera but I am pleased that the Ricoh engineers included a way of getting 35mm.
4:3 Ratio
3:2 Ratio
1:1 Ratio (square)
28mm is 75 degrees
35mm is 63 degrees
