streetshot
marky
windsor girls
Good shot! The only problem I see in not well selected resampling method. With Lancozs you will get much better result ;) You can try also the Bilinear method, but then you will most probably have to resharpen it a bit.
Scaling the picture down makes it always a bit soft, so it's always good to add a bit of sharpening after resizing the photo. But Bilinear is especially soft resampling method.
