With iso set on auto(camera is at 3200 max limit set), using snap focus set at 2.5 meters to infinity for maximum depth of field, aperture at f8, as expected meter is using a low shutter speed to allow for more light.
Despite low shutter speed limit is set at 1/60th, as something needs to give, meter decided to adhere to maximum iso set vs raising the iso, but resulting in camera shake;
Is the best way to raise shutter speed without losing the desired depth of field, override and raise the iso higher manually?
