R8 & R7 - difference in WB performance
R8 WB performance is significantly improved over the R7. It varies under different lightning conditions, but it's definitely changed. The difference is especially visible in Auto and Cloudy WB mode. R8 WB is now much closer to the real colors. I have to admit I probably liked a bit more the orange cast of R7 Cloudy WB. Pity there is no custom WB option as in case of GRDII, which allows to setup WB according of the photographer's taste ;)
R8: 50mm, 1/203, f4.2, ISO100, -0.7EV, Cloudy WB, Sharpness - Soft, Color Depth - Neutral, F3:2
full size file > here <
R7: 50mm, 1/189, f4.2, ISO100, -0.7EV, Cloudy WB, Sharpness - Soft, Color Depth - Neutral, F3:2
