lucridders
Hello, I am new to this forum and I was buying a few months ago the GX100. I have to say that I was buying because I found lots of good critics on the internet about Ricoh. Now that I have it a few months, I have to say that the weekness of this camera seems to be for a lot of people the reason why they buy it. I have several complains:
1- Noise is at an unacceptable high level and has nothing to see with a film grain as sometimes mentioned on the internet. This is noise in maybe the most worst level I ever saw.
2- Sharpness is missing, or you need to take a picture where you can not notice it. There is that much noise that nobody can find a good algoritm to make those images sharp. It seems they they need to look around a little bit to other manufacturers!!!!
3- The software is missing quite a lot of tools that you do not understand why they do not put this in the camera. Per example the bracketing for EV. This is settable at 0.3? Why not up to 2 so that HDR can be used!!! So we have lots of small issues missing in this camera.
4-EVF = very bad. Do they use this themselves while testing a camera. I do not think so otherwise they have to discover it themselves quite soon. They use a separate EVF = good idea in fact. But why not using an EVF that is a little bit bigger????
5-Ricoh seems to be the company who is doing the most new firmware of all. This says a lot about the testing they do in advance!!! = No testing. When on the otherhand making new firmware, it is all the time that kind of new firmware that is not giving you more control over the settings or similar things. Just a few stupid adjustments that you can miss in fact.
6- Wobbling lens. Do not tell me that this is normal. Yes it is normal when you make things in the cheapest way. Do not also tell me that this is not affecting the picture quality regarding sharpness!!!
7- Flash is worthless. Is it in the year 2007 still impossible to make a flash that is controlled by the camera si that over-exposure is eliminated??? You have a good strong flash but you can not use it right away, untill you change the EV with even 2 stops???? Whats the difference between normal flash and soft flash, seems that it is not quite different in the tests I made!!! So, again an example that cameras where not tested before selling.
So, I have still a few other points (at least 10) but this will bring us to far. Anyhow, this is a camera that is below average and far below. I saw also a topic here from a consumer that is also asking to put lots of things more in the firmare. I have to say that he is completely right.
Also some good things:
1- Build quality is very good
2- some good and nice controls to make it easy while taking pcitures.
3- good strong flash, but not possible to use as it is overexposing the pictures all the time.
Conclusion:
All advertsing about this camera is just overacted. Could be a good camera (when studied first as it has to be) but in the way they sell it now, it is not a camera of 2007!!!
I found that Ricoh was selling a new camera, the R7 They advertised with a new processing engine making less noise. To see if it was correct, I bought one and I have to say that this camera with the so called new engine is making noise also as no other brand. So, in the future, I stop buying from Ricoh untill they solve those major problems.
I will go on by using my old sony 717, is 5Mp but working much better.
Conclusion:
