Wiener
A question to those who have encountered and discussed such problems elsewhere on the forum, if you don't mind?
Apart from what appears to be the 'usual' learning curve to acheive images in focus, this lens seems to produce reasonable images with good contrast and colour. However, there is evidence of colour seperation close to the edges where horizontal lines are set against bright light. For example, on the attached image the cross above the chapel roof shows blue rims above and red rims below the horizontals. I am guessing this is 'normal' due to a mis-match of lens design and sensor. This may not prove to be such a huge problem as it is not present in many images (and certainly not in b&w!)
And comments from the old/young and wise will be much appreciated.
all the best,
all the best,
