Myself, as well as a group of friends, has bought a set of the Subject recently. We then tested it but the result is very disappointing.
We found out that there is one fatal feature of the camera which made photography very difficult, on many occasions almost impossible. It happened when we are using manual mode and rely flash as the light source. We then noticed the brightness of the LCD has been designed as a kind of light metering at the aforesaid setting. That is, it will become much dimmer at “under exposure” setting. On many occasions, it is so dim that we cannot even see the subject and do any composition. We have used other cameras at similar setting but no such problem is encountered, the metering will be notified in the form of nos instead of LCD brightness.
Said, you may agree with me that this is a serious issue and I hope your good company can provide a solution in the very soon future. Our opinion is that the LCD brightness should always be maintained on a normal level and the metering will only noticed in other form.
