GXR doesn't keep date
eurostar
Hi to the forum, after some years of no use, I recharged the battery of my GXR and switching on, first thing the camera asked was to set the date. But after I set it off, and then switched on again, it asked again to set the date. I guess the internal battery is dead. is something replaceable by the user? Thanks in advance.
Guido
Perhaps you need to format the camera without a SD card to clear internal memory. Just throwing that out there.
I found on another forum the advice to fully charge and discharge the flash, and it worked. Thank you for your answer.
Hi eurostar. Requesting to share the link or steps to also fix my GXR body internal battery concern. Thanks in advance!
