Hi guys, I'm relatively new to my GXR, but I have a question regarding flash triggers, specifically the Yongnuo RF603 (for Canon) I own, combined with the Yongnuo 560II
With the flash directly connected to the hotshoe, the flash fires without problems, but when the trigger takes its place, the flash does not fire.
The flash itself only has one central pin while the trigger has five (4 pins in a square pattern behind the central pin. When I go to remove the trigger, the flash fires, indicating the communication between the trigger units is fine.
Could it be that the surplus pins are preventing the camera from firing the flash somehow?
