odklizec
PK
I finally got a chance (thanks to Ricoh Europe) to try the TC1 tele extension lens for GX100/200 cameras. This extension lens expands the GX100/200 zoom from 72mm to 135mm (35mm equivalent). As each Ricoh extension lens, TC1 is a very well build lens with minimum optical distortions and defects. I'm still amazed how good results can be delivered with Ricoh extension lenses. Usually, any additional lens element put in front of the camera lens, and which is not an integral part of the main lens, more or less degrades the image sharpness, adds or pronounces the chromatic aberration or corner softness/vignetting. Neither is the case of TC1.
The TC1, as each extensions lens, makes the camera much bigger. I'm afraid, it can no longer be called "compact" or "pocketable". On the positive note, it's still smaller than any DSLR/EVIL camera setup with similarly specified lens. And if you detach the lens, you can still keep the camera and lens in the separate pockets. The TC1 comes with integrated lens hood. All you need to do is to pull it on, which is very easy process. Although integrated, it does not wobbly and the hood lock/release mechanism is very snappy.
So, what's the main advantage of this lens? Aside the longer focal length, it allows to produce some blurry background, which is usually very hard to achieve with small sensor camera. Sure, one can produce some background in macro mode. But only if the camera is very close to the photographed subject, which is a bit impractical for portraits and candid shots With TC1 you can make some nice portraits with separated background even at 1-2m distance. Sure, it does not match the quality of the blurry background produced by the DSLR with bright portrait lens starting at f1.4. But it's still useful and I'm personally pleased with the results.
The only other downside of this lens (aside the size of GX+TC1 setup) is that the starting F number at the camera tele end is f4.4. This + relative long zoom makes this lens practically unusable under bad lightning conditions (with shutter speeds under 1/40 or so). Also, the f4.4 at the tele end is not the sharpest GX100/200 aperture so it's better to stop it down a bit (f5.6 is great).
My conclusion is that this lens is great addition for everyone seeking longer zoom and nice portrait lens. TC1 is exactly what you look for. It's great lens under the ideal or almost ideal lightning conditions. But don't expect miracles when it comes to badly lit rooms. Also, the camera with attached TC1 is less than pocketable.
Here are some real world samples:
