GX100 RAW writing speeds with various SD/SDHC cards
Hi folks,
Although the GX100 is not the direct GRD successor, it seems that Ricoh significantly improved the major GRD weakness, which is too slow RAW writing. But the same as in case of GRD, you will have to use the proper SD/SDHC card to get the maximum out of the GX100! Thanks to GX100 guys at DPReview Ricoh forum, in the below table you can see the summarized RAW writing times for different SD/SDHC brands & sizes..
Code:
The "# BLINKS" is just the number of blinks of the camera AF led light. This light apparently shows also the writing progress.
Sorted by number of blinks, where 1blink = cca 0.5sec.
SD/SDHC CARD TYPE ..................................................... # BLINKS
2GB Sandisk Extreme III ............................................... 8 (Australia)
4GB Panasonic Class 6 SDHC Gold (RAW+N640) .......................... 8-9
2GB Sandisk Extreme III ............................................... 9 (Italy)
2GB Sandisk Ultra (Extreme) III ....................................... 9 (Italy)
(Assume member meant Extreme III, as there is no Ultra III)
2GB Kingston 50x SD ................................................... 9
2GB TwinMOS Ultra-X 150x (cheap) ...................................... 9
2GB Adata 150x SD ..................................................... 9
2GB Transcend 150x .................................................... 9
2GB Transcend 150x (Non-SDHC) (RAW +FINE JPEG) ........................ 9
4GB ATP Promax SDHC Class 6 ........................................... 9
4GB Kingston SDHC Class 6 ............................................. 9
4GB Lexar Platinum 2 60X .............................................. 9
4GB Lexar Professional 133x ........................................... 9/4secs
4GB Sandisk Extreme III ............................................... 9
8GB A-Data Class 6 (Raw + N640) ....................................... 9
2GB Sandisk Extreme III ............................................ 9-10
2GB Kingston elite pro 50X (Raw + N640) ............................ 9-10
8GB SanDisk Extreme III (Class 6) .................................. 9-10
16GB SanDisk Ultra II (Class 4) .................................... 9-10
2GB TRANSCEND SD 150X ................................................ 10
2GB Sandisk Ultra II (USB version) ................................... 10
2GB Sandisk Ultra II ................................................. 10
4GB Sandisk Ultra II ................................................. 10
4GB A-Data SDHC Class 6 .............................................. 10
8GB Transcend SDHC Class 6 ........................................... 10
16GB AData Turbo Class 6 SDHC (RAW+FINE) ............................. 10
2GB Panasonic Class 4 SD Blue (RAW+N640) .......................... 10-11
1GB Sandisk Ultra II Plus ............................................ 11
2GB Sandisk Ultra II ................................................. 11
2GB Kingston Elite Pro 50x ........................................... 11
4GB D.Media SDHC Class 6 (RAW+FINE+color - 6 sec) .................... 11
4GB Apacer SDHC Class6 ............................................... 11
1GB Corsair .......................................................... 12
1GB Integral High Speed (66X) ........................................ 12
4GB SANDISK SDHC Ultra II ............................................ 12
4GB Transcend SDHC Class 6 (RAW+FINE) ................................ 12/7secs
4GB Verbatim SDHC Class 6 ............................................ 12
8GB Kingston SDHC Class 4 ............................................ 12
4GB Kingston SDHC Class 6 ......................................... 12-13
4GB SANDISK SDHC ..................................................... 13
2GB Sandisk MicroSD ............................................... 13-14
4GB PNY SDHC Class 4 ................................................. 14
4GB Toshiba SDHC Class 4 ............................................. 14
2GB Lexar Professional 133x (RAW + N640 JPEG) ..................... 14-15
8GB Patriot (Class 6) ............................................. 14-15
4GB Sandisk SDHC (expensive) not speed branded ....................... 15
1GB Toshiba AUD$20 not speed branded ................................. 16
8GB Transcend SDHC Class 2 (purchased in San Jose CA ) ............... 17
2GB Standard Kingston SD (RAW+Fine) .................................. 17
1GB Kingston MicroSD .............................................. 15-18
512MB ordinary Sandisk .............................................. ~18/9secs
64MB Sandisk TransFlash .............................................. 19
512Mb Crucial (speed not specified) .................................. 19
1GB Patriot 40x (Non-SDHC) ........................................... 20
2GB "My Memory" (online shop own-brand) 133x SD ...................... 22/11secs
4GB PQI SDHC Class 6 ................................................. 22
2GB Fujifilm 60x ..................................................... 23
32MB SanDisk ......................................................... 34
64MB Sandisk ......................................................... 49
GX100 internal memory .......................................... 56 to 58
BTW, if your GX100 can write RAW under 8-9blinks/4-5 secs, don't forget to tell us about it! But even if your card is not the fastest card, please, drop your # of blinks/times here too! It would help the other people not to buy SD/SDHC cards, which are not suitable for RAW.
Thank you!
Re: GX100 RAW writing speeds for various SD/SDHC cards
added 2GB Lexar Professional 133x (RAW + N640 JPEG) ..................... 14-15 (NEW)
sandisk ultra II 2gb...........11 blinks
added 2GB Sandisk Ultra II (USB version) ................................................... 10
added..
1GB Integral High Speed (66X) ..................................... 12
512Mb Crucial (speed not specified) ............................... 19
hehe..unusable slow XD cards and now also SD? Thanks for test!
Results with my cards:
SanDisk Extreme III 2 GB SD - 9-10 blinks
SanDisk Extreme III 4 GB SDHC - 9 blinks
Kingston Class 6 4 GB SDHC - 12-13 blinks
Here's two from Tennessee:
PNY 4GB SDHC Class 4, takes 14 blinks
A-Data 4GB SDHC Class 6, takes 10 blinks
I am about to order the GX100 and need help please! The specs I have say 4GB SDHC max.
But this thread seems to indicate 8GB works. If I could order 16GB, I would!
Class 6, of course. What is the max GB for the GX100, please!
Unfortunately, I don't know about anyone who tested 16Gb card with GX100. But as it takes 8GB cards, I don't see any reason why the 16GB cards should not work as well? The GX100 is SDHC compatible and the SDHC is about "High Capacity". For example, 16GB card works fine with GRD2 (as reported here).
But personally, I would recommend you to get two 8GB cards (or maybe 4GB) instead of one large. At first, the bigger cards are often slower. See the GRD, GRD2 and GX100 list of cards and speeds. The same brand and speed class is usually slower in case of larger capacity! At second, even flash cards can be corrupted! It's a very good idea to use several smaller cards instead of one big.
4GB pqi SDHC Class 6 and 22 blinks ! (Yes,22. Not a typo).
Just received a brand new 4 GB SDHC branded pqi. Supposedly, it's a Class 6 card.
$14.99 and no shipping was a good price.
Performance not so good. 22 blinks seems to be as low (slow/fast) as it gets. So, more like a class 2 at best in reality.
Good to know, not least since I saw a 8 GB Class 6 card from pqi for $25. I pass on that one.
I formatted the card both in camera and computer. No difference.
Btw, I bought it from a well known/rated retailer, not eBay, so it should be genuine enough.
Cheers
Roger
Heres a few more. RAW+jpegfine
Transcend 4GB Class 6 SDHC 12 blinks(don't know why its so slow)
Lexar Platinum 2 60X 4GB 9 blinks
AData Turbo Class 6 16GB SDHC 10 blinks
The display says the 16GB card will hold 839 RAW+jpegfine!
No longer using these as they were too slow but I originally got a time of 11 secs (~22 blinks) with "My Memory" (online shop own-brand) 2GB 133x SD card, and about 9 secs (~18 blinks) with an ordinary Sandisk 512MB card.
Kingston 50x 2GB SD ...9 blinks
Toshiba Class 4 4GB SDHC ...14 blinks
Thanks for your reports guys! All timings should be in the list now.
8 GB Patriot (Class 6): ~ 14-15 blinks (very cheap, fully sufficient for time-lapse shooting)
8 GB SanDisk Extreme III (Class 6): ~ 9-10 blinks
My new Transcend 8GB SCHC class 6 card . . . 9 to 10 blinks
Regards
