odklizec
PK
This is a test of GRDIII battery performance in Interval mode. Tested both DB65 and older DB60. It's just a reaction on GX200 test done > here <.
GRDIII JPEG, infinity focus, all sounds OFF, LCD brightness set to 50%, freshly charged batteries.
Interval set to 10 minutes.
DB60 - 1150mAh
LCD ON
LCD OFF
DB65 - 1250mAh
LCD ON
LCD OFF
DB60 - 1150mAh
LCD ON
- - 19 frames (including first manually taken frame)
- first frame - 10:59
- last frame - 13:59
- runtime 3:00 (max + 9 minutes)
LCD OFF
- - 24 frames (including first manually taken frame)
- first frame - 9:09
- last frame - 12:59
- runtime 3:50 (max + 9 minutes)
DB65 - 1250mAh
LCD ON
- - 22 frames (including first manually taken frame)
- first frame - 14:02
- last frame - 17:32
- runtime 3:30 (max + 9 minutes)
LCD OFF
- - 30 frames (including first manually taken frame)
- first frame - 19:46
- last frame - 00:16
- runtime 4:50 (max + 9 minutes)
