Wiener
Hi Guys,
having finally taken the plunge into the GR pool I immediately hit a serious problem more or less first time out of the box.
On power-up the camera froze and would not allow a picture to be taken (SD card blank, on inspection). Worse still, it would not power off leaving the lens cover open and extended. On removing and replacing the battery it simply retracted the lens then extended it again, once more entering the frozen state. I eventually had to place the camera into my coat pocket and continue without a camera (pity, the snowy woods looked amazing!) On returning home I once more took the battery out but this time, following reinsertion, it worked perfectly.
Battery was fully charged at the time though firmware was still Ver. 2.03. I have now updated to 4.0. I am now wondering if I should replace it or hang on until it is better tested out. Does this problem sound familiar with any other GR user? All feed back appreciated!
