Trying to figure out which to use or both. If you're using the onboard flash and you want for example +1 stop, should you set the flash exp comp, or the camera exp comp. Within the camera is there any connection between the two. Would a combination of both ever be advisable - say in a fill flash situation?
Any light you can shed (no pun intended) on this would be greatly appreciated.
Thanks.
Thanks.
