Tom Caldwell
[CORRECT METHOD SHORTFORM]
Select start settings on your selected host/transfer camera back to "read from module" (use a module where loss of existing settings does not matter - a new module is no problem). Switch off - remove "scratch module". This will set your "scratch module" to whatever settings that the host camera back contained (volatile memory settings are saved to body AND module). If your GXR back(s) already wet to "read from module" this step is unnecessary.
Insert existing module with your desired settings (modes, functions, etc), switch on (thereby reading module settings into volatile memory).
Without switching off or removing this module - select start settings read from body [IMPORTANT], switch off (this records your newly read volatile memory start settings to body AND module).
Insert new module, switch on (read body settings into volatile memory), switch off (thereby saving volatile memory start settings to the body AND module).
Repeat with all modules you wish to upgrade. (Include the first "sacrificial" module from step one as this would have been reset to defaults if used with a new GXR back set to defaults).
At the last module synchronised select start settings read from module before you switch off (to preserve the future module settings from being over-written and also to make sure that multiple camera backs always act the same with this module mounted).
Enjoy
Enjoy
