Hi All...My GX 100 suddenly can't see my installed external SD card. I've tried every card I have in the slot, but it only sees the internal memory. When I use the menu to try to format the external card, it says to install a card. I've tried everything I know to do including leaving the battery out to reset the camera's software. All I can think of is to re-install the latest firmware via direct hook up of the camera to the computer since it would not see a card with the firmware installed on it and see if that takes care of it, IF that is possible. Has anyone heard of this happening with the GX100 or have any ideas? Many thanks.
Frank Weir
frankweir@yahoo.com
Michigan, USA
Frank Weir
frankweir@yahoo.com
Michigan, USA
