The GR DB-65 battery is meant to be used in a GR or G700 / G700se
It can be used in other cameras that normally use a DB-60, but its voltage will be lower.
DB-65 has 1250 Ah 4.5 Wh 3.6V
DB-60 has 1090 Ah 4.1 Wh 3.7V
DB-65 will fit GRD GRD2 GRD3 GRD4 & G600 also.
Its always bestist to find the correct battery for your camera if possible, just to safeguard the electronics.
